Se non sbaglio l’altezza sella è 890mm. Ho provato a salire su una all’Eicma ed è troppo alta per me (173 cm). Potrebbe andare, ma preferirei qualche cm in meno. 840mm?
È una moto che si riuscirebbe ad abbassare? Come?
To make a low seat, we have to remove some foam. In some cases, that has an effect on comfort. Due to the thickness of the factory foam, sometimes we need to increase foam density on our low seats to prevent the rider from bottoming out on the pan in certain terrain. In all cases, there will be less foam than the stock height seat. In most cases, the low seat option is designed for people that really need the extra reach to the ground and understand that it may be a bit more firm than our standard or tall seat.
Low: Lower than stock height, usually about one inch (25mm) lower [SMC-R = 15mm]
Comfort: The Comfort seat is wider than stock. This our standard seat.
Giax ha scritto:consigliano di infilare la forca di 30mm
