anteprima rc8 r 2011
gluca
Messaggioda gluca » 1 nov 2010, 8:57
Tratto da http://hellforleathermagazine.com/2010/10/entire-2011-ktm-model-line-up-leaks/
Sempre secondo loro:
"A new crankshaft, refined fuel injection and new dual-plug ignition increases power from 168 to 175bhp and torque is up 1.5lb/ft to 93.6. That crank, the injection refinements and a new, heavier flywheel should address the main complaint people have of the RC8: an aggressive surge of power as it comes on-cam. When you’re fully leant over and that happens it can upset things. It’s not a huge deal, but people do bitch about it; hopefully no longer. KTM claims these changes also marginally improve fuel consumption and reduce emissions.
On the handling side, KTM claims its thoroughly revised the suspension giving it a wider range of adjustment than before. These changes include a new eccentric linkage for the rear shock.
Then there’s the looks. KTM clearly employs the best graphic designer currently working for any OEM. Loud, but classy, the two-color paint schemes perfectly accent the RC8’s sharp, geometric lines. Color us impressed. Oh and there’s a new LED running light."
massimo
Re: Rc8R 2011
Messaggioda massimo » 1 nov 2010, 11:22
però ce lo potevano lasciare il carafango anteriore in carbonio! speriamo che i cerchi siano quelli della R o che per risparmiare non abbiano messo
due cerchi in ferro!!!!! :rotlf:
Re: Rc8R 2011
Messaggioda Dade » 1 nov 2010, 11:45
colorazioni assolutamente SPETTACOLARI!! :shock: I cerchi sono i fusi normali, suppongo che per venire incontro alla clientela "normale" abbiano rinunciato ad un po' di agilità in favore di un sensibile contenimento dei costi, riversato sul motore....
Del parafango in carbonio chissenefrega, non è sto gran risparmio di peso, è solo figosità in più o in meno, ma con questa grafica non lo si noterebbe neppure... :wink:
Ah... gommata SportSmart!!! :mrgreen: :mrgreen: :mrgreen:
Re: Rc8R 2011
Messaggioda Dade » 1 nov 2010, 11:48
bellissima!!
sembrerebbe che l'arancio della carena sia metallizzato...
Re: Rc8R 2011
Messaggioda Dade » 1 nov 2010, 12:05
...e comunque meglissimo nera piuttosto che bianca... Applausi!!
micbrugo
Re: Rc8R 2011
Messaggioda micbrugo » 1 nov 2010, 13:47
boh
molto SD come grafica.
continuo a preferire la mia bianca. de gustibus.
grafiche bocciate :roll: non mi piacciono.
speed
Re: Rc8R 2011
Messaggioda speed » 2 nov 2010, 19:26
MI PIACE MOLTO BIANCA, SI SA A CHE PREZZO DOVREBBE USCIRE ?
Skeb21
Re: Rc8R 2011
Messaggioda Skeb21 » 2 nov 2010, 19:34
Beeeeelllla!!! :shock:
superduca
Re: Rc8R 2011
Messaggioda superduca » 2 nov 2010, 21:41
Dade ha scritto:...e comunque meglissimo nera piuttosto che bianca... Applausi!!
Quotone carpiato. Molto bella !!
andrea
Re: Rc8R 2011
Messaggioda andrea » 2 nov 2010, 22:01
sbaglio o monta le sportsmart di primo equipaggiamento???? 8)
andrea
Re: Rc8R 2011
Messaggioda andrea » 2 nov 2010, 22:03
nera va di più!!!
è assodato!
è una roba da :seghe: d'urgenza!!!! :mrgreen:
Vincenzo
Re: Rc8R 2011
Messaggioda Vincenzo » 2 nov 2010, 22:29
La nuova RC8R con doppia candela per cilindro.
E la nuova RC8R TRACK
vincenzo@myktm.it
tasso
Re: Rc8R 2011
Messaggioda tasso » 3 nov 2010, 7:43
prendo la track!!!!!!!!!!!........................... :mrgreen: :mrgreen:
micbrugo
Re: Rc8R 2011
Messaggioda micbrugo » 3 nov 2010, 11:11
la novità più grossa è il twin spark. chissa che botte!!
per l'uso mio la standard è perfetta.
queste comincio a vederle delicatine con 180cv....
queste sportsmart si stanno facendo largo!
8)
lespaul
Re: Rc8R 2011
Messaggioda lespaul » 4 nov 2010, 12:43
Clamorosamente figa. :wink: :wink: :wink: :wink: :wink:
lespaul
micbrugo
Re: Rc8R 2011
Messaggioda micbrugo » 4 nov 2010, 12:55
tasso ha scritto:prendo la track!!!!!!!!!!!........................... :mrgreen: :mrgreen:
complimentoni e BRAVO!
facci poi sapere come cambia l'erogazione con il twin spark
chissa che acelerazione!!!!!
:wink:
Re: Rc8R 2011
Messaggioda Dade » 4 nov 2010, 15:35
lespaul ha scritto:http://static.blogo.it/motoblog/ktm-2011-mega-gallery/big_ktm_02.jpg
no ma la stai guardando quella tuta Alpinestars cosa non è????????? :shock: :shock: :shock: tra quella e la moto ho bisogno di una pannolone da mettere sotto alle mutande!! :crycry:
micbrugo
Re: Rc8R 2011
Messaggioda micbrugo » 4 nov 2010, 15:43
la tuta merita un topic a parte.
cosi come i guanti GPpro ktm della alpinestars....
PANNOLONE! :mrgreen:
andrea
Re: Rc8R 2011
Messaggioda andrea » 4 nov 2010, 15:44
a me nera piace di +!
in ogni caso è una roba da .... :love1:
Re: Rc8R 2011
Messaggioda Dade » 4 nov 2010, 15:45
micbrugo ha scritto:cosi come i guanti GPpro ktm della alpinestars....
I GPPro li ho comprato l'anno scorso e ne sono STRAFELICE.... :D :D
Torna a KTM RC8 Superbike
