Suzuki news - RM-Z450 e RM-Z250 2012
Messaggioda jenk » 21 giu 2011, 18:04
Le moto rimangono pressoché invariate rispetto allo scorso anno
Sarà la crisi economica, sarà che ormai le moderne MX hanno raggiunto quasi la perfezione, ma di novità vere e proprie quest'anno ne abbiamo viste davvero poche. Così anche Suzuki si allinea al trend generale e per le RM-Z 450 e RM-Z 250 2012, conferma in toto i modelli 2011. Gli unici cambiamenti visibili ad occhio sono i nuovi elementi di protezione per gli steli forcella in nero e la sella bicolore in rosso/nero.
2012 RM-Z450
Chassis
Overall Length 2190 mm (86.2 in)
Overall Width 830 mm (32.7 in)
Wheelbase 1495 mm (58.9 in)
Ground Clearance 325 mm (12.8 in)
Seat Height 955 mm (37.6 in)
Curb Weight 113 kg (249 lbs)
Transmission 5-speed constant mesh
Final Drive Chain, DID520MXV4, 114 links
Suspension Front Telescopic inverted, coil spring, oil damped
Suspension Rear Swingarm, link type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Disc brake
Tires Front 80/100-21 51M, tube type
Tires Rear 110/90-19 62M, tube type
Fuel Tank Capacity 6.2 L (1.6 US gallons)
Engine
Engine 449cc, 4-stroke, liquid-cooled, single cylinder, DOHC
Bore Stroke 96.0mm (3.780 in) x 62.1mm (2.445 in)
Compression Ratio 12.5:1
Fuel System Suzuki fuel injection
Starter Primary kick
Lubrication Suzuki Advanced Sump System (SASS)
Ignition Electronic(CDI)
2012 RM-Z250
Chassis
Overall Length 2170 mm (85.4 in)
Wheelbase 1475 mm (58.1 in)
Ground Clearance 345 mm (13.6 in)
Curb Weight 104.5 kg (230 lbs)
Final Drive Chain, DID520DMA4, 114 links
Tires Rear 100/90-19 57M, tube type
Fuel Tank Capacity 6.5 L (1.7 US gallons)
Engine
Engine 249cc, 4-stroke, liquid-cooled, single cylinder, DOHC
Bore Stroke 77.0mm (3.03 in) x 53.6mm (2.11 in)
Compression Ratio 13.4:1
Ignition Electronic (CDI)
