news ktm 450 rally
Inviato: 27 mag 2010, 15:19
ho trovato in rete alcune info, sempre se sono attendibili, riguardo alla nuova rally 450 che sembra la stia testando Despres.
probabilmente un eventuale acquirente che ha chiesto info in ktm per l'acquisto.
From KTM today:
Please find attached the technical detail of our 450 Rally bike,
which will be available for Dakar 2011.
Our quotation will be as follow : Price 450 KTM Rally: 29.300,-- Euro (without VAT)
Price spare engine (max. 2): 5.000,-- Euro (without VAT)
Bike painted in sponsor basicolor: 1.000,-- Euro (without VAT)
Production date: October 2010Closing date (for orders) : 15th of June
Pictures of the bike we will send you soon (1 – 2 weeks).We are looking forward to hearing soon from you!
Best regards
KTM Rally team"attached specs:450 Rally Replica 2011
Engine
Engine type Single cylinder,
4-strokeDisplacement 449cc
Bore / stroke 97 / 60,8
Power n.s.
Torque n.s.
Starter / battery Electric starter / 12 V 8.6 Ah
Transmission 5 gears, dog clutch engagement
Fuel system Keihin FCR-MX 41
Control 4 V / OHC with roller rocker levers
Lubrication Pressure lubrication with 1 Eaton pumps
Engine oil Motorex, fully synthetic, SAE 10W-60
Final drive 15 : 48
Cooling Liquid cooling
Clutch Wet multi-disc clutch, hydraulically operated
Engine management / ignition Keihin DC ECU
Chassis
Frame Chromium-Molybdenum trellis frame, powder coated
Subframe Self-supporting plastic tank
Handlebar Aluminium, tapered, Ø 28 / 22 mm
Front suspension WP-USD Ø 48 mm
Rear suspension WP-Monoshock with Pro-Lever linkage
Suspension travel front / rear 300 / 310 mm
Front brake Brembo two-piston, floating caliper, brake disc Ø 300 mm
Rear brake Brembo single piston, floating caliper, brake disc Ø 240 mm
Rims front / rear Spoked wheels with aluminium rims 1.60 x 21'' / 2.50 x 18''
Tyres front / rear 90/90-21"; 130/80-18"
Chain X-Ring 5/8 x 1/4"
Steering head angle 62.5°
Trail 120 mm
Wheel base 1,535 ± 15 mm
Ground clearance 320 mm
Seat height 980 mm
Tank capacity approx. 35 litres
Weight (ready to race) under 150 kg (without fuel)
Who wants to buy one? Pay now. Delivery (slightly used) in February 2011. They'll sell one to us, but probably not to the general public this year at least.
From KTM today:
Best regards
Engine
Power n.s.
Torque n.s.
Final drive 15 : 48
Chassis
Trail 120 mm
Seat height 980 mm
