ziocane comincia a costare la roba
quelli di emig sono molto efficenti, ho scritto una mail questa mattina e mi hanno gia' risposto
Yes, you can buy the Revolution to use on the clamps you got. The only part you need to complete the kit for the 950ADV is the post, $50.00 and the Revolution $350.
To then use the same Revolution on the 530 you need under the bar mounts that will mount on to your OEM 530 top clamp and the bolt on post.
You can see the UTB mounts here:
http://www.emigracing.com/utbktmoem.htmand the post here:
http://www.emigracing.com/ktmstab.htm To summarize:
Revolution $350
950 Post $50
530 Post $75
OEM UTB mounts $130
figa altri 600$
e in piu' bisogna sommare spedizione e dazi doganali
se sommo i 500neuri delle piastre per l'adv arrivo a 1000+ euro
