Ciao neeko!! Come fai autoapprendimento centralina per clima estivo?
(fonte riportata più e più volte su advrider e ktmtalk):
"2. Idle reset procedure
The 'famous' 15 minute idle reset procedure. This resets the adaptive base values of the ECU. It won't transform the bike but it can make a worthwhile improvement. It is very important that the engine is stone cold. One or two hours after riding is not enough! Do this after the bike has been off for a full night or day. Start the engine and let it idle for 15 minutes without touching anything. After 15 minutes, switch the engine off with the ignition key. Done. During this procedure you won't see or hear anything happening besides the idling and (probably) the fan. Don't worry, the reset is done. Besides after certain maintenance or parts replacement, you could consider doing it twice a year with the turning of the seasons. A reset for the colder autumn & winter period and one time for warmer conditions during spring & summer. This is not mandatory or needed and don't expect miracles."
(http://www.monomaniacs.nl/tnt/KTM-690/S ... tle-issues)
loloc30 ha scritto:ottimo!! io domani sera monto il completo GPR
loloc30 ha scritto:Ragazzi dopo aver messo il gpr mi sento come un bambino a cui han portato 3 kg di caramelle gommose. Ha un sound fantastico anche con db killer.... Se lo tolgo penso sia da arresto.
Il risparmio di peso é notevolissimo!
Credo siano almeno 7-8 kg
Dopo lo peso
Adesso faccio l'auto apprendimento
