da ale22 » 7 ott 2019, 7:40
Anche a me capitava come @Ruotagrassa.
Poi ho provato a fare come descritto su un sito relativo ai problemi del 790 : Avviare la moto premendo lo starter solamente per una frazione di secondo, come fosse l'interruttore di casa ed effettivamente non mi è più capitato.
Riporto il testo originale :
''There are reports of cold start issues. The engine starts, but stalls right away, requiring multiple tries to start and hold idle.
Before looking at anything else, try following this foolproof start procedure:
Make sure the kill switch is in the neutral position (Better, when you stop the engine with the kill switch, train yourself to always put it back in the neutral position right away);
Put your key in, turn the power on;
Listen to the fuel pump building pressure in the circuit. Wait until it stops. Note that this priming will not happen if the kill switch is engaged. The manual recommend waiting until the instrument panel starts, which takes roughly the same time as the priming;
Don’t touch the throttle;
Tap the start button. Don’t keep it pressed until the engine fires, just give it a tap and the engine will start by itself.
If this doesn’t start the engine every time, or if the engine stalls right away, check your fuel filter for contamination and the pressure at the fuel pump (or ask your dealer to do it). Note: Filters are black when wet, white when dry: don’t assume a dark filter is a dirty one.
If it stills acts funny, talk to your dealer.''
