Cambio automatico...perplesso....
liam
Messaggioda liam » 6 lug 2015, 20:21
http://youtu.be/HROvCXuPcz8
Prevents engine stalls:
Using principles of centrifugal force this clutch automatically engages and disengages base on RPM. This means you can come to a complete stop, in gear, without touching the clutch lever, and your bike stays running. Trouble finding neutral at a stop light? Never have to worry about that again.
More traction:
Core EXP delivers smooth and manageable power, providing high performance and traction control unique to the auto-clutch line.
Retains manual override:
You can override the clutch at any time just like a traditional clutch, never use the clutch again, or use both methods throughout the ride/race. With a clutch lever that feels and functions just like stock and engagement characteristics very similar to a manual clutch, you may not even realize this clutch is in your machine until it saves you from a time wasting stall or effortlessly powers you through that otherwise tiring section. Gold on an Adventure bike.
Superior durability:
Improved design reduces friction and heat build up by allowing more oil to be pushed through the clutch components. Updated wedge design also provides much better longevity than any previous design.
costello
Re: Cambio automatico...perplesso....
Messaggioda costello » 6 lug 2015, 20:44
Diventa uno scooterone
Inviato dal mio LG-D855 utilizzando Tapatalk
sbkduca
Messaggioda sbkduca » 6 lug 2015, 21:23
in enduro qualcuno la usa.. rekluse.... funziona similare..... funxza benissimo ma potenze limitate non traspette 185 cavalli.. h ah a hahhahaha
ciao tortello...
redbud
Messaggioda redbud » 6 lug 2015, 23:11
Io la uso sul cross... Ottima... Ma è stata fatta anche per la sd?
Inviato dal mio SM-G800H utilizzando Tapatalk
Messaggioda miscelatore » 7 lug 2015, 4:13
io la uso sull'enduro, l'ho avuta in passato su una moto da cross, e lo provata anche sull LC8. Mi ritengo abbastanza soddisfatto e ne sono un estimatore.
Ma non riesco proprio a vederne l'utilità su una moto stradale come la superduke.
liam
Messaggioda liam » 7 lug 2015, 7:43
qualcuno mi può spiegare il funzionamento???!!!!
Messaggioda miscelatore » 7 lug 2015, 12:31
Dal lato pratico, o dal lato tecnico?
Dal lato pratico non hai bisogno di usare la leva frizione per partire da fermo o parzializzare nel traffico o nei tornanti. Cioè stai guidando un Tmax con l'aggiunta del cambio rapporto.
Dal lato tecnico invece ci sono delle masse e delle molle, che in base alla rotazione hanno la forza di comprimere il pacco frizione
sbkduca
Messaggioda sbkduca » 7 lug 2015, 12:35
unico difetto cheposso trarci è che se cadi in enduro il motore non si ferma....e se la ruota posteriore non ha stop o no è bloccata tende a ruotare , quindi a volte rompe un poco le balle.... poichè non è mai a frizione staccata completamete.... ma anche li si riesce a regolare un poco.... la mia fa cosi... è una delle prime... credo che adesso abbiamo fatto modifiche importante ma rimane frizione per uso speciale.... ovvio....
liam
Messaggioda liam » 7 lug 2015, 13:36
miscelatore ha scritto:Dal lato pratico, o dal lato tecnico?
posso buttare pure la leva del cambio e quella della frizone? :rotlf: :rotlf: :rotlf: :rotlf:
sbkduca
Messaggioda sbkduca » 7 lug 2015, 19:33
Butta la moto vala e prendi un Tmax...
